Work continued on the right wing forward spar and trailing edge installation. Images 1 shows the right wing with forward spar and attach fittings drilled (including all reinforcement brackets. The inboard forward spar for the left wing has also now been formed and can be seen resting in place (not drilled or adjusted). Image 2 shows the trailing edge ribs at BL:16.5 and 24.5 drilled in place.
Right wing forward spar drilled in place
Right wing T.E.ribs drilled
Right wing substructure mostly fabricated (not riveted)
