Drilled hinges onto the aft Hz tail spar. the space between hinges is supposed to be 0.45 inches, so I made a spacer block to make the setup constant and parallel. I also used the temporary set-up pins available through Avery tools (Avery is located on my airport, so it's easy to get things that may be useful.
