Kit comes with a complete wiring harness that has a circular pin connector that can disconnect so the instrument panel can be taken out and worked on separately. All wires are pre labeled and as I was checking it out I found two that were mislabeled. (Fuel Pump & Starter) Wire gage the same so simple fix was to swap labels at instrument side.
Used Silicon Tape at both ends of circular pin connector.
