Brief Description: Tail Boom Wiring for Position Lights
The grommets are automotive window washer motor mounts. Only one sent with kit and I assume it’s for the outlet next to mast. I use two more for the outlets to the horizontal stabilizer. These grommets are and extremely tight fit. Mast was very difficult to get in. On the back I cut the tubing in v shape and they push right in. It also gave room for and covered up the wire ball that feed to the left and right positioning lights.
