Brief Description: Upper Engine Mount Weldment Modification
Orv Neisingh, a Rotorway CFI, mentioned an incident where the engine fore/aft adjustment bolt stripped out the threads in the casting causing loosening of the main drive belts. I epoxied an additional nut on the inside of the casting to help prevent the weaker casting threads from galling.
