The factory recommended method for draining coolant from the engine is to tilt the tailboom down, remove the two hoses from the lower engine elbows and the let the coolant fall into the bottom of the fiberglass tub and drain out.
In consultation with RWI technical support I chose to drill and tap two holes into the lower engine elbows for petcocks to make the draining much easier.
