THOMAS'S WEB SITE
Date:  3-4-2004
Number of Hours:  8.20
Brief Description:  Mounted Main Rotor Bearing
Installed the main rotor thrust bearing and bearing flanges in the hood bracket of the airframe. It was necessary to trim the back edge of the flange a smalll amount to allow adjustment of the fore/aft position of the main rotor mast. I aso had to elongate the bolt holes fore/aft in the hood bracket to allow movement of the bearing flange. 3.0 of the above hours performed on 3/5/04.
