Brief Description: Vertical Trim Fin Rear Bracket Modification
The rear attachement point of the vertical trim fin to the tail boom was via an aluminum double and a nut plate. Several builders suggested fabricating a metal bracket like the forward bracket used on the vertial fin. I cut, bent and drilled a 1/8 inch thick steel strap which makes the whole area much stronger.
