Dr. Pete's Xenos Build
Sonex XenosB
XNS-T08
Clips, Ruddervator Drive Plate
Completed four parts fabricated 2" angle.
Used a bench vise to open the 90 degree angle. Opened angle to approximately 100 degrees , relaxed to 95.3 degrees.
Drilled, deburred, Cleco'd drive plate and root rib. Deburring and fininshing the edge with a
Scotch-Brite wheel as demonstrated in this EAA video
Bend the starboard drive plate up rather than down even though I had it clearly marked. working too late in the evening resulting in a $16 mistake to replace the part. Time to quit.
Ordered replacement drive plate. Backordered for a couple weeks.
L&R clips
Hockey sticks and clip.
Ruddervator drive plate and rib
Sonex XenosB Home
1277
Cockpit
25
43
Communications
Cowling
198
149
Finish
89
Hangar
60
261
Instrument Panel
49
76
Legal-FAA
Research
