Brief Description: Trailer and Make the Lights light up
Photo 1 is my platform for the front blade support. Notice the piece of pipe laying down on the trailer. This will stab into the upright pipe. I used tread plate for the platform so that when I stand on it to secure the blade I will have some grip.
I decided to try to program the VP-X Sport electronic circuit breaker. This requires some software downloaded off the internet, computer and the supplied Ethernet cable. My first attempt was unsuccessful because when I turned on the Master there was no juice. This was traced to a ground wire that was not hooked up. Fixed that and made the connection.
After I told the VP-X what each device was I was able to monitor the current draw and status of each. It told me that I had a short circuit in my CoPilot Mag. In the process of debugging this I found a couple of other wiring issues. This was really helpful, a great tool.
The last photo is the MGL Odessey with all of the probes hooked up. Unfortunately most of the temperatures are wrong. The EGT and CHT are correct but all the others are wrong and is the oil pressure (145 psi). More troubleshooting.
