The first step in assembling the rear fuselage is to match drill the side skins to the longerons. The longerons are the only items that need to be drilled. All of the other parts are ready to cleco together.Having pre-drilled parts is a huge time savings and will help to assure a straight fuselage. Tommorrow, I will assemble the bulkheads, match drill the bottom skin and then begin assembly.Things should move along rather nicely from here on out.
