two days Covered left side of fues. Intersting, like it would not work, but by just pulling and tugging and tacking down, it went on. Had to trim out the excess near the top of the fues to get it to fit due to the curve. Glue down the bottom longeron and then just work around the front and back to the tail and it covers with only a couple of small loose areas. Ironed out at 250 and was Ok.
Put on the right side and it was the same only a little more difficult for some reason. Got it all on and glued up to the fin.
