After trimming and sealing down the edges of the bottom fabric, shrank it to 250 degrees.
Marked the bottom tube where the side fabric overlays and then put on the glue. Put fabric on and started trying to get a good "lay" for most of the area. Was interesting, not sure what that means.
Am using a white Stewart System glue for the fues. fabric. It leaves pencil lines visable which makes trimming edges, like the bottom tube cut line, visable. Cut bottom line and glued it. Started on the forward part. Not sure how the whole thing will go together, but at least you have a 10% shrinkage available to get a good final product.
