Cleaned up the hanger, swep up a ton of rivet shanks. Got out the leading edge wrap and stiffiner and cledoed it to the wing. Put on the tip wrap, bent it to shape and drilled it into the tip and #11 ribs. Came out well. The L.E. wrap is about 3/16 shorter than the root skin, so removed the skin and trimmed it back so the skins will be straight. Removed the fuel tank amd marked the location of the fittings.
Was the second sunny day in the worst winter we have seen in a while. Temperature never got over 34, so pulled out the RV-10 and the wife and I went over to Mt. Jefferson. Real nice trip, eastern Oregon is mostly snow covered. Expect snow/sleet/ice the next two days.
