The Velcro I used on the rugs does not stick well to the rug. Works fine on the aluminum, but comes off the rug very easily. Experimented a bit with contact cement and fabric adhesive and then hit on hot glue. Hot glue works very well, so removed all the rugs and added hot glue under the velcro. Installed all but the front rugs.
Made the seat belt bushings and installed the rear seat belts. Started on the overhead front belt.
At the hardware store while getting more hot glue, discovered that they have strip stainless material available. Got some 1" X .028 to bend up for a seat belt and headset hangers.
