Sanded cabin top and doors. Spread dry wall compound on all surfaces. Started sanding it off, did the doors and rear of top.
Put epoxy primer on sanded portion with brush. Will wet sand and then shoot with another coat later. A couple of areas to rapair showed up as expected.
Operations manager at glider field tomorrow, no work.
