Removed the clips and outside protective tape. Pulled back tape from outside edge. The inside tape line, the black/white tape edge in photo 2, looks very clean.
Decided that the outside fiberglass will butt up to that line and will be tinted with black so it will not be visable if the line is not perfect. The paint line will also be the outside fiberglass line. The glass at the bottom will have to wait until the cabin top is onn for good since it will overlap the top rivets.
Started puting fiberglass line tape on one window. Will need to order black pigment and some 2" tape (thought I had more than I do) to go much further. Can do the door windows except it is turning hot (almost 90) for Oregon and I melt at 85.
Relations will be here Tues thru Friday so will get the break I need.
