Brief Description: Motor mount, MM/fues ground, oil cooler mount
Drilled out the last motor mount holes. Two were about 1/16 off center, but just drilled with the 3/8 cobalt drill and lots of Beolube and they went without a hassle.
Made the ground strap that runs from the motor mount to the small forest of tab mount. Had some 3/4" copper braid that could be shaped to fit inside a lug with a 5/16 hole. Bolted to the firewall.
Edged and deburred the oil cooler mount, nutplated it and riveted to the firewall. Put a 10/32 nutplate to be used to mount the Antisplat Aero oil seperator.
