Bruces Web Site
Date:  11-6-2012
Number of Hours:  4.00
Brief Description:  Controls, pushrods, sticks
Cut and drilled the two long tube pushrods. Primed interior and left to dry til tomorrow. Built rocker, and internal pushrods.
Did all the stuff to assemble the sticks and installed in the aircraft. Will remove the sticks and stick mounts tomorrow and replace the stick bolt with a taper pin like in the -6A The 3/16 bolt allows some play in the joint and the controls. A B&S Taper pin locks the stick in place and makes the system completely tight.
