Brief Description: Finish all side section, steps, instrument panel a
Finished minor details in the side section of the manual. Still need to do bottom rear rivets before putting the tailcone on.
Completed the steps. Will put an access hatch in the baggage compartment to get to the bolts, so they are drilled and removed for now (and my shin's protection). Doing the first part of the step before the sides were on made this very easy. Doing the mounting blocks with the side skins would have been a major pain, especially the right where there is no baggage door.
Started on the upper front. Cleaned up edges on all the parts and put on a bunch of nutplates. Clecoed it together after bending the bulkheads 7.3 degrees (right!), drilled out the rivet holes and installed on fues. Gets it away from the boat look. Clecoed on the Instrument panel just for looks.
