Brief Description: Calivrate fuel tank levels, misc. details
Picked up another 20 gallons of fuel. Put 5 in a tank and pumped it out. Flowmeter measured 5.3 gallons so I adjusted the meter constant. Did it again and it was about 5.1. Another adjustment. Put 30 gallons in the left tank.
Set up the calibrate of the right tank and plumbed the discharge to the tank. Pumped all 30 gallons two at at time while calibrating the right tank level. In the end the flowmeter showed 30.3 gallons total. Adjusted again. The pumped it all to the left tank at two gallons a pop to calibrate the level. This time it was 30.1 gallons, close enough for now.
Did another two items on the punchlist after the ACS order from Sunday arrived. Engine run tomorrow if the rain holds off.
