Bruces Web Site
Date: 1-22-2014
Number of Hours: 5.00
Brief Description: Flaps, fuel line, fuel level, ailerons
Connected the controls to the ailerons at the root, not final until ailerons are on and allignment is verified. Put on both flaps, cotter pins on mount bolts, connection to flap drives finaled. Oops, the flap switch was backwards. Reversed 2 wires to the flap drive and it is correct. Flared fuel line connection and made up loose, need to remove and access the connection at the tunnel, which is still loose, and blow them clean and then final. Connected wire to the two fuel tank level senders.
Put the left aileron on. Need the right to verify everything is correct, according to the plans they should be perfect, but that is not necessarily true.
