Bruces Web Site
Date:  1-13-2014
Number of Hours:  4.50
Brief Description:  Rugs, seats, seat belts, belt holder
Continued on rugs. Put in the two fronts to finish it off.
Drilled the holes for the overhead front belts in the cabin top. Had to make due with the countersink becasue of the 5/16 bolt. Mixed some flox to fill the sink and make the screw flush. Installed the front lap belts and seats.
Made a upper seat belt holder out of 1" wide stainless. Installed in the overhead console. Put the seal on the overhead console cover plates to make them air tight and installed.
Printed two copies of each sheet of panel lables and sprayed with fixative. Will remove panel and put on lables tomorrow. Rest of interior is finished for a motor run.
