Brief Description: Light Speed, plug wires and baffles
Made up the Light Speed coil wires. Anchored and tied down as necessary.
Made several trials of the plug wire layout until I found one that used what was provided and had some sense. Made four brackets to anchor the plug wires to the injector line brackets and installed. Light Speed is done.
Started working on the bracket air leaks. The major one is the two back pieces that do not fit tightly to the engine case. They overlap it but do not fit down tight. Glued them on with some engine adhesive and hopefully they will stick. Much more to do on this project.
