Brief Description: Seats, fix Skyview radio mount, cowl
Did every thing to install right seat.
When I mounted the Skyview radio, the cut-out was done after the main panel was completed. I somehow got it off so it was not square with the 10" display by about 1/16". Since it was only about 1/2" away, the mistake stood out like I couild not believe. Filed the edges of the radio cut-out until the thing was parallel to the display. Turned out the mounting holes could take the slight twist and it is now dead on. Something like this would bug me every minute I flew the aircraft!
Worked on cowl to remove the bondo that was used to hold the foam when it was the mold for the plenum.
