Continued on the Aerosport pin covers. Removed blanks and installed nutplates. Trimmed as required. Put cowl back on airplane and worked a bit on fitting the pin covers as they did not come out as planned. Had to trim slightly around the edges. Apparently the pin I used to hold the top and bottom together was not long enough and the cover blanks sprung the cowls so they did not fit with the pin all the way in.
Got interrupted by 5 cubic yards of compost. Spent most of the day moving and spreading it in the yard. More tomorrow, and need about 4 more yards.
