Bruces Web Site
RV-10
Cowling, top side hinges, Aerosport pin cover
Riveted the top cowl side hinges on.
Laid out Aerosport cowl pin cover and cut opening. Taped the temporary blanks in place and glassed the inside of the cowl.
Put the rear baffels back on and checked for trim. Will require some but the cowl will fit as is for the trim marking.
Tomorrow continue on the cowl and look at the neighbor's plenum to see if his aluminum top is the way to go or if I will do it out of carbon fibre.
S-20 Home
RV-10 Home
2745
350
Doors and Latches
310
Finishing details
Flight Testing
1005
Overhead console
Soaring
Tailcone
