Brief Description: Filler, sand doors, filler, door strut bracket
Sanded the glass over the door hinges and placed a layer of filler. Also filler on some of the door problem areas.
Cut in the overhead to install the aftermarket door strut bracket. Required more filler to fill in a small gap. Most likely will have to caulk them when the top is painted.
The fiberglass I laid up for door operator covers stuck to the glass. Was not the same glass I usually use. This was coated with some sort of thin plastic. Made up another sheet of 4 layers laid up over wax paper.
