Made a piece of thin aluminum to glue to the back side of the strobe/run light on the tip. Will act as a shield for any RF generated by the system.
Made up the right wing wires to the strobe/run light and the taxi light. Used a seperate plug for each. Grounding is interesting for the AeroLED type. The VAF forum had the best imformation of how to implement their wiring diagram. Hope it works.
Realized I did not have enough wire to run the pitot heat and landing light. Needed some -14 so ordered from Vans after 4PM. Bet the wire will be here Thrusday.
