Brief Description: Lacing wire, brackets and cable supports
Started by removing the cables from the instrument panel and removing it with both screens attached. Took about 10 minutes and exposes all the wiring and devices as seen on photo 3. With the top skin on it will take longer because you have to remove the 10" screen, pull it out and remove the cables, then the 7" and then the radio and panel plugs. Plus the massive number of screws Vans uses to hold the panel in place.
Laced the main run behing the switches. Built a support to hold it. It was mostly self supporting when laced, but needed at least one brace to keep it from moving under load. The cable controls like cabin heat run just above the run.
