Continued lacing wires and installing cable clamps to support runs.
Built a 16 tab ground buss that bolts to the firewall. It will connect to a flex cable from the motor mount when that is installed. Five higher current devices are grounded at the bus and there will be three wires from the homemade Skyview hub/ground bus to ground the 15 or so grounds that go to that location.
Received the oil cooler mount from Vans that I ordered Tuesday night, One day delivery, great USPS.
Talked to Vans help line about my flap actuator. It makes a much louder sound going in one direction that the other. They had me remove the motor and check it and it ran fine. Looking into the actuator it looked like the gear was being ground down so they are sending a new one out today. I will send them this back to look at and listen to.
