Bruces Web Site
Date:  5-11-2013
Brief Description:  Testing , wires for PAR00EX entertainment
Slight interrruption, 11 cubic yards of topsoil mix arrived thru the hanger to provide a better garden. Spread about 4 yards, rest tomorrow
Figured out the wig/wag issue was simple, the grounds for the system were not connected, still have to make an airframe ground tab that connects the engine ground strap to the airframe and picks up a couple of high current grounds.
Noticed that the PAR100EX entertainment 1 input does not go to the back seat unless plug J2 pin 22 is grounded. So added a wire to the plug to the pilot/copilot plug in center consolet and one to ground. Need a minature switch to complete. Thought of another ground that needs running and then forgot it. Will drive me crazy tonight.
