Cut hole for a 25 pin Dsub just below the EMS module. This is the EMS ground/power distribution buss. 13 pins soldered together and hooked up to the custom Skyview hub ground bus, 4 pins to the EMS 12V bias voltage, and 8 to the 5V bias. All the EMS instrumentation that uses a bias voltage and ground will be hooked to this Dsub and eleminate problems with grounds.
Ran the resestive fuel level wires to the wing area. Had to order some small bushings from Vans this Sunday P.M. Bet they will be here Tuesday A.M.
