Bruces Web Site
Date:  4-5-2013
Number of Hours:  1.50
Brief Description:  Transceiver mount
Built PAR100EX transceiver mount. Consists of a piece of .063 drilled to rivet to the skin with four 6/32 csk head bolts with slots cut in the head and aluminum and pins to lock from rotation. These are set in JB weld. They are flush with the back of the mount.
Worked on the two Skyview harnesses. Removed almost all wires from one that will have to be made about 6" longer.
