Brief Description: Correct schematics, elevator trim, tail light/stro
Worked on my Skyview hub pin number issue. Finally got it right and corrected all the schematics. Did find an error on one connection on the board, fortunately it is correctable with a sharp knife and a jumper that I made provisions for in the design.
Decided to go to the rear of the A.C. Built three Dsub 9 pin connector mounting brackets and installed one on the trim assembly. Wired the plug male and female. Pulled the trim cable and the strobe/run light wires up to the cabin. Anchored the conduit installed in the tailcone build.
