Drilled holes to run wire thru the stick and stick mount. Only required 5/16 hole in pilots stick and 1/4 in copilot. Put in bushings and pulled wired.
All but two of the eleven wire ID tags came off the pilots wires in the pull. Put D sub pins on all the wires and spent some time sortingt them out an putting in the 15 pin plug. Wired the copilots with a 9 pin plug and laced both wire runs.
