Bruces Web Site
Date:  2-8-2013
Number of Hours:  2.50
Brief Description:  Doors, buildup gutters
Sanded rough spots on previous gutter layup and laid another on the left and first on the right. About two more rounds to go to get the thickness, then the top goes on and the gap gets set, top off and trim to 1/4" and fill and fix the back side.
Installed the pilots seat and put in cushions. Got in and made motor noises. I have the 10 and 7" Skyview cutouts on the panel. Checked out where I can put them and taped in place. The 10" was placed in the center of my line of sight and as high as possible. Tthe 7" will go just to its right with the tops level. The radios will go the the right and the remaining piece of panel will be easily removeable and contain a glove box
The fuse panel and the Dynon stuff will be on the back bulkhead. I plan on using auto fuses for all but the alternator field which will be a switch/breaker. I used a fues panel in my -6 and have yet had to open the little door on the instrument panel to access a fuse in flight. Never burned out one yet.
After sitting in the pilots seat and adjusting the seat forward, I ordered an IFFLRV10 adjuster extender kit.
