Continued or right door. Assembled all the parts and had it working. I changed out the bottom straight gear in the left door where the lock latch was too far away from the end of the gear. This means that the other door straight gear to the front is a little too short which is Ok because I made a slightly longer piece of pin using leftover Vans pin tube. Need to keep the parts straight on this thing.
The top gear hit the elbow pocket, cut it out. Glassed and filled in the area where the lock goes.
