Installed lock in left door. Works well but should have mounted it about 1/4" closer to the door handle Will have to make a lock plate to reduce the gap.
Removed right door. Drilled for and installed guide blocks from Plane Around. Drilled hole for Vans latch and cut a notch for the lock. Mounted Plane Around gearbox.
