Bruces Web Site
RV-10
Stick and misc.
Drilled one stick for the taper pin. Other is on hold while I get a taper pin macined down to size. Installed some of the control stick in final.
Riveted up the pushrods and then primed the outside. Can install tomorrow. Mounted the elevator autopilot servo mount on the bellcrank frame.
Brake line fittings arrived in the mail so will do the lines tomorrow. Mounted the brake reservoir.
S-20 Home
RV-10 Home
2745
350
Doors and Latches
310
Finishing details
Flight Testing
1005
Overhead console
Soaring
Tailcone
