DAVE'S WEB SITE
Date:  6-19-2007
Number of Hours:  1.30
Brief Description:  Mounted sensors/Reinforced broken glass work
Worked on reinforcing the broken glass areas. We're now up to three layers of cloth in the broken areas. There will still be some vertical development that isn't accounted for, so I'm thinking potentially a fourth layer will be necessary. I think if I'd had the braket there and bolted into place I would have been fine...damn the hindsight! I will make that a priority as soon as the glass/fill work is done.
I also mounted the majority of the engine sensors. They basically live on one of the supports for the radiator now. I took the aluminum piece they were all mounted to, cut off a bit, rounded off the corners and made it work. The additional good news is that I was able to utilize one of the extraneous holes I had drilled in the root tube. I also came to the conclusion that the two sets of plugs coming off the ignition 'sensor' are the same dang thing and they can then go to either ignition module...eureka. I'm finding that the engine wiring is slowly dropping into place as I start affixing stuff. I know I'm at the very beginning of this process and there are a lot more wires to hook up, but I'm feeling slightly better about the whole damn thing.
Talked with Charla for a while tonight. Things continue to go well. I found out I was hurting her with my peacock comments.. I'll have to lay off those, certainly don't want to make her self concious and withdrawn. I love her for who she is, and wouldn't want to hurt that, but at the same time I don't want her being a fat-head. I think she is predisposed to being big in the britches, which I love, but I think could also hurt. This relationship stuff is hard, but I find it interesting, involving, and fun with her. These are all good signs, me thinks.
