Worked on prepping the wing some more. I tied up the wiring harness so it wasn't flopping around as well as added some more Goop to its connection points.
I drilled all the rivet holes in teh bottom of the wing, and then deburred them.
I cleaned up the leading edge, sanded the wingtip smooth, and adjusted the wiring harness so I can get it out later.
I knocked out as many dents as I could.
Finally, I went through and put two coats of the pink-stuff on the wingtip.
Tomorrow I will have to put the fabric tape everywhere, glue down the felt, and then cover it!
Showing the Laser alignment
Showing the wiring harness being supported off the bottom fabric
