I created a drill jig to redo all the fabric riveting holes. As much as I hated to duplicate that effort, I think I will be very glad. To locate the holes I made one mark on the root rib where I wanted the hole, and one on the tip rib. I then set my laser line up on the ladder and adjusted it until I had a straight line inbetween the two. I then took the jig and drilled the damn holes...something like 75 of them! I also deburred all of them on the top of the wing. I will have to do the bottom tomorrow.
I also got some Goop today and redid the wiring harness hold-down.
Finally, I mixed up some epoxy/microballoons and filled the incorrect fuel fill hole. I will have to continue to work on the area on the turtledeck that the pylon crunched out on the trip out here.
