Continued work on the pylon side covers. Trimmed right side to shape and size. Drilled holes for rivets/screws.
Cleco'd entire side panels on. Used rivet fan to set drill spacing...it actually worked out brilliantly. Unfortunately when I drilled the first side (rt side) I drilled for 1 1/2" spacing and after looking at it decided 3" is a much better solution. I will rivet the right side on, and then fillthe holes with whatever Norm recommends.
