Lots and lots of misc shit taken care of today. I installed the ELT. I will still need to install the remote antenna (something I'd hoped to avoid) but otherwise the bracket is in the plane.
I refiberglassed the holes in the fuse the wobbling motor made.
I fiberglassed the hole left by moving the fuel filler. I will need to add multiple layers to this.
I relocated the fuel filler to align it better with the fuel fill. Now it should have a straight shot into the tank and prevent 'backwash'.
The comm antenna was installed behind the seats on the rt side. This put it just behind the right rear window. That placement is further aft than I was anticipating, but the different window orientation necessitated that.
I hooked up the fuel tank vent.
Vic convinced me to not hook up the heater right now. I can easily do that later, and it is a lot of headache that I simply don't need right now. Besides, it will greatly simplify the whole troubleshooting process to begin with. The plan will be to get it functional at the first annual.
