Worked on getting the elevator trim actuator attached and functional. Long story short I had to take the thing apart and put it together three different times beacause I failed to READ the instructions. It uses the AN-4 thin nuts instead of the normal ones.
The other part of the issue is that I can't seem to find the trim plates. I need to look at the pictures I have on here and on the CD. I found something that I think are those plates, BUT they don't seem to be 'finished'. What I mean by that is that there is a lack of a 45 degree cut and a lack of a second bolt hole. This may be totally normal, or it may be these parts go somewhere else, or it may be that these parts were never finsihed...who knows.
I ran out of daylight, time, and inclination tonight. I'll check the trailer tomorrow to see if there is anything else hiding in there, then Ill call PA.
