Installed the lower sub panel today!! It doesn't sound like much, and the actual act of it wasn't, but the lead up sure was. I had to install the foredeck in its 'mostly-final' configuration prior so the lower subpanel would fit correctly when the foredeck was actually screwed in place.
The foredeck didn't want to fit correctly at its trailing edge where the canopy fits in place. I had to hack a way a bunch of the lip on the hull and that seemed to help a bunch. It is 85% correct right now and I'll have to use a heat gun to fix the rest. It's ALWAYS something. Regardless it looks pretty darn good and will only get better as I reform it.
Vic came over and looked at the panel and was shocked. He hasn't seen the airplane all that much lately, so he sees the big changes. Much like watching a kid grow, the grandparent is able to see major changes whereas the parents aren't as able.
