Continued fitting the turtle deck. Marked lines for rivet holes and began Cleco'ing it together. The right side is laying down nicely, the left is causing problems. Each end fits ok (minus the comments about the back from last installment), but the middle overlaps too much. I decided to put down the project and walk away for a little bit. I think I will pull out all the Clecos on the left side tomorrow and start anew on that side. I'm also considering what it would take to lower the boom where it meets the back of the hull.
