Derek & Kims RV-9A Build Log
Date:  9-17-2012
Number of Hours:  3.00
Brief Description:  Aeroled Wiring & Connectors
Ran 3 conductor shielded Tefzel through the wing conduit to the wingtip and installed the Kit provided molex connectors. Used Solder sleeves to install a ground lead to the shield. Protected connections and wire with sleeving and heat shrink. Verified all ground connections with the continuity reader on my multimeter.
