Brief Description: Prepared right elevator hinge doublers
Separated and cleaned the edges of E-00001A/B hinge doublers. Hand filed the top and bottom spar-facing edges of E-00001A to fit inside the edge of the right E-702 spar. Cleco'd E-00001A, E-00001B, E-610PP, E-611PP and two K1000-6 platenuts to right E-702 spar. Drilled all common hinge holes with #30 drill bit.
